11-12-2006 07:32 PM
11-13-2006
12:11 PM
- last edited on
03-25-2025
11:40 AM
by
Content Cleaner
Hi lukejc,
Any user that uses a logging task must have write access to the VI Logger Database. The default database is located under C:\Program Files\National Instruments\Shared\Tagger\database. Most users won't have write access to this folder. You need to enable write access to this folder for all users. You can do this by right-clicking on the folder and select Sharing and Security, click on the Security tab, and select whichever group you're in (most likely the Users group), then check the Write permissions box in the Allow column.
With VI Logger Full, you can create a new databases where all users have read and write access. You do not have the ability to create/manage databases in VI Logger Lite, so you will need to upgrade to VI Logger Full if you wanted to use this solution.
I hope this helps!
- Erik
