VI metrics: number of diagrams
Hello everybody,
Does anyone know what "number of diagram" refers to in the context of the VI Metrics tool
Thank you.
BR,
Pablo
(2,755 Views)
If I had to guess I would say it is talking about things that are found under the Structures Palette.  Things like Disable Diagram Structures, For Loops, While Loops, Case Structure, Event Structures etc.
(2,734 Views)
Accepted by pablopaolus
Hoovahh is correct. Any white space within a structure is also called "subdiagram".
This is significant when it comes to "nesting" of diagrams. It is recommended to have a maximum nesting depth of diagrams of about 5 per VI.
If your algorithm requires a deeper nesting level, use subVIs to abstract nesting.
Norbert
Norbert
Expert: Geometry
(2,726 Views)
Thank you Hooovahh and Norbert!
(2,700 Views)
