VI running very slow in a new PC
Another thought, is there any difference in the antivirus/firewall software installed on the computers? I have seen both effecively slow down disk accesses.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 17
(1,455 Views)
Both PCs have different antivirus. The older PC haseset nod 32 and the new has windows defender that comes with windows 8.1. I've already tried with windows defender and firewall turned off but it still has the same problem.
I've noticed that only the nimxs.exe processes are being limited, the other processes don't have any problems accessing the disk.
Message 12 of 17
(1,448 Views)
Crazy thought: What happens if you unplug the network cable?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 17
(1,439 Views)
Have you tried mass compiling or force compiling (ctrl+run) the VI's, or are you running a compiled .exe?
/Y
Qestit Systems
Message 14 of 17
(1,434 Views)
I'm connected through wifi, and if I disconnect my wifi connection I don't receive any data from the PLCs and I don't register anything on any of the databases. So the VI runs fast in that situation and the disk usage stays at 0% most of the time.
I already tried to mass compile and the log didn't gave me any warnings and it continues with the same problem. Trying to force compile didn't change anything either.
Message 15 of 17
(1,418 Views)
Hi, I know that this is a really old post, but I was wondering if you found any solutions to this problem.
I am currently going through the exact same problem and I cannot find solutions anywhere.
Message 16 of 17
(1,300 Views)
That was a long time ago indeed!
I never found a solution for it. I just used the PC where I didn't have that problem.
I don't have that code anymore or those PCs anymore. It was for an academic project and I didn't have much LV experience at the time. Now I'm a LV developer with a CLD certification and I can tell you that my code wasn't that good! But it was working! Haha
I remember that I was writing a lot of data to the Citadel database in the same VI using multiple write functions. That wasn't obviously the best way to do it. But what was strange was that the performance was so different between the PCs and the PC with better specs was the one with those issues.
Are you also writing data to a Citadel database?
PS: I'm the original user (Mateus23). I have a different NI account now.
Message 17 of 17
(1,293 Views)
