VI to stay on top of Excel and any other applications
How do I keep my main VI on top of all other windows, i.e. Excel? This simple concept seems to escape me. The Floating Window Behavior doesn't appear to do the trick.
Please advise.
Message 1 of 12
(4,022 Views)
Open the properties dialog (ctrl I).Select the window appearance category, select customize, and set it to modal.
Jim
LV 2020
Message 2 of 12
(4,021 Views)
This doesn't appear to work, as when I try to move my cursor to another cell in Excel, the VI goes behind Excel.
Message 3 of 12
(4,014 Views)
You will need to call windows user32.DLL functions. First to get the window handle, and then to set the z order of the window. Setting z order to -1 sticks the window to the top of all applications. I can probably find an example for you when I am back at work in the morning.
good luck,
Michael.
Message 4 of 12
(4,006 Views)
Rivers, that would be most appreciated.
Message 5 of 12
(4,004 Views)
Accepted by Eric1977
Just use the Windows API Function Utilities for LabVIEW. It has a VI in there to set a window on top.
Message 6 of 12
(3,998 Views)
I have written an example for this using native dll calls as promised.  Copy the dll nodes to your application to preserve the paramater setup.
Stop the VI using the Close X, not the abort button, or your window will be stuck on top!
All the best,
Michael.
Message 7 of 12
(3,984 Views)
Is the Windows API functions available in LV2010 SP1?
Message 8 of 12
(3,965 Views)
If you are referring to the link I sent you, then just download the 8.6 version. 2010 can open 8.6 VIs. You can then simply resave them.
Message 9 of 12
(3,962 Views)
Thank you. That worked!
Message 10 of 12
(3,956 Views)
