VI works Execuable does not work
ok, from the first smaller screenshot that might be confusing, so here the explanation:
part one are the outputs, (valve settings, etc):
(for better handling i keep an Boolean array with the status of each Output)
part two are the "non critical" input signals:
part three are the critical Inputs,
so i store them in the Cluster:
main reason is the security handling:
additional to the three Loops of the QMH I created a fourth on, which only handles security issues (like open housing, emergeny button,..)="Task Sec"
for handling those Inputs  in another loop I had to create this in another "section" as accessing from two loops in the same task array does not work.
Message 11 of 17
(952 Views)
Him GerdW
thanks for the input, I hope I could clarify the first points of your reply,
the other ones:
  • Using BytesAtPort to determine the number of bytes to read is considered "non optimal" behaviour…
    • I know, when I was programming, this was in in the examples so I kept it.additional it works.
      BUT: if I have time, I'll replace this
  • Using local variables when the terminal is unused is considered "bad style".
    • where do I do this??
  • Using locals when a shift register should be used is considered "bad style".
    • where??
Message 12 of 17
(948 Views)
Hi Wolf,
where??
Look out for "Enum message out". Both times…
Message 13 of 17
(943 Views)
ah, I'm using this only for debugging. thereby at debugging I can see which case was used, so this is nothing for the GUI or the user
back to the main question:
why does this not work?
I think I can exclude the file path.
I take a look at the folders and the Program does create the Logfile and it has content, so this works
so it remains:
VISA Configuration
and initialization of the I/O's
any suggestions what the error could be?
Message 14 of 17
(906 Views)
Hi Wolf,
@WWolf78 wrote:
so it remains:
VISA Configuration
Which errors do you get for both items?
Message 15 of 17
(900 Views)
the I/O's does work, as after initialization I check some of those and thereby I get no Error, so this works
when I try using the Serial communication I get this one:
Message 16 of 17
(894 Views)
ok, got the source for this one:
it was the invoke note at the beginning from the VI.
after deleting I don't get the error any more
and very curious:
now the VI and the serial communication works
now I'm confused
ok, additional I've disabled the checkbox here:
could have been this the reason?!?
Message 17 of 17
(885 Views)
