VIPM Woes
OK...so I am having a similar situation to this post.  I am trying to build a package while preserving the directory heiarchy.  The folder that I am trying to build looks like this:
On the left is the source directory.  On the right is the deployed directory.  If you notice, there is an extra folder in the deployed directory called Typedefs; this should not be there.  This folder actually resides in one of the other folders.
If I look in the vipm build spec (file called spec), I find this line:
File 71="vi.lib/MSR Consulting, LLC/General Reuse/Typedefs/Session Handle.ctl"
Does anyone have any thoughts as to why this is showing up in the build spec like this?  That folder needs to be in the place I specify, not pushed into another directory.
(3,170 Views)
Accepted by topic author cirrusio
Never mind.... it  appears that the value Use Destination of Parent Folder under Source File Settings somehow got unchecked.  Carry on.
(3,152 Views)
