VIPM crashing. File \2019\tptable.tdr missing.
After a reinstall of LabVIEW my VIPM now crashes on opening.
The error log indicates that I have the following file missing: C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2019\tdtable.tdr.
The Knowledge Base article here, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Ru8SAE&l=en-GB says I can copy the file from a working installation on another machine. Could someone provide me with me a copy of the file please. Specifically the file from the folder above, as the same filename exists in other folders.
TIA
Aim for the moon and the stars . . . and if you only hit the outhouse roof at least it's progress in the right direction.
(1,961 Views)
Accepted by topic author M31vyn
This is the file, although I have no idea if it would help you. I would suggest considering a repair/reinstall of the RTE.
___________________
Try to take over the world!
(1,909 Views)
Thanks for the file. Much appreciated. But I have to admit that I got impatient and did actually end up doing a complete un-install and re-install of all my NI stuff instead. It was a complete PITA but appears to have had the desired effect.
But, thanks again.
(1,882 Views)
