XNET dynamic create Session problem
Hello guys,
my idea is to load a CAN database from an init file and get the signals with the database and cluster property nodes. With this signal I want to create a session. I have built a very basic VI just to test this basic problem, but I can't figure out why I only get 0 values. When I add the signals with the signal constant and select them manually, it does work.
Attached is the VI and a picture of the relevant part of the program.
So when I compare two signal names, they seem to be different, the signal from the path has a number added to the database name, the one from the constant hasn't:
I really appreciate your help !
Philipp
(2,339 Views)
This question is best to be posted on the Automotive and Embedded Networks
I guess it is because a dbc file is not loaded with a baud rate by default hence a baud rate of 0 is being used. You should try to Set Baud Rates
(2,304 Views)
@ttersonR wrote:
I can follow all instruction but some loop error show how can i solve.
It's urgent please help me.
Best regard,
TtersonR
What error are you seeing? Please post your code otherwise we don't know what you are trying to do.
Are you trying to load DBC dynamically as well? If not, please do not hijack other's thread and start a new post.
(2,265 Views)
That was the solution
Thank you very much !
(2,227 Views)
