VIPM installation problem
Good afternoon, everyone. My name is Leong, and I have the problem to install the VIPM after I download the VIPM from the website. I installed the NI labview 2009 run time software, the message display as the below:
Error 5 occurred at an unidentified location
Possible reason(s):
LabVIEW: File already open
May I know that what is the problem so I know how to solve it? Thank you for your kindness help.
(4,780 Views)
Is the error from VIPM installer, or from the LabVIEW Run-Time installer?
If from the VIPM installer, you may have more luck searching the VIPM forums: VIPM forum
Try reading this post from Jim Kring: How come I get error 5 during VIPM installation?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(4,773 Views)
Dear Thoric. Thank you for your kindness to provide me the solution in order to overcome the problem I faced. I solved the problem according your solution given to me.
Sincerely yours,
Leong Yun Siong
(4,765 Views)
Accepted by ArduinoProject
You're welcome.
Don't forget there are Kudos and Accepted Solution buttons you can select - these are most appreciated Smiley Happy
(4,762 Views)
Leong, you should press the "Accept as Solution" button next to Thoric's reply. Also you should press the Kudos button. That means that you like his reply.
LabVIEW 2012
(4,761 Views)
Thank you, Steve. I owe you one.
(4,737 Views)
