VISA ERROR MESSAGE
I am running the following small routine to start up a VISA session. I am reading from a Thurlby Thanda 1906 multimeter. It works perfectly with Hyperterminal.
The error I am getting is as follows:
Error -1073807246 occurred at an unidentified location.
Possible reason
VISA: the resource is valid, but VISA cannot currently access it.
The error occurs at the VISA serial step.
Any ideas?
Nevica
(2,432 Views)
Read this first: http://www.ni.com/support/labview/visa/verr3.htm
If you still have a problem, please post back.
Also, make sure HyperTerminal is not running.
(2,425 Views)
