VISA Error code
I have this error code when run the labview code,
BFFF009Eh: a code libry required by VISA could not be located.
Can someone tell me what it is?
(5,666 Views)
Check out this thread and see if it helps.
http://forumstage.ni.com/ni/board/message?board.id=140&message.id=9863
If not, repost with your results.
Kenny
Kenny
(5,660 Views)
I get BFFF009E for the same message.  Where can I download the library for VISA Read/Write instrument commands?
(5,608 Views)
Look here.
(5,586 Views)
Hi rig32 and TigerB,
Just to clarify things, this error message usually means you either don't have NI-VISA installed, or you have a corrupt installation. See the knowledgebase linked below for some more information:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P87BSAS&l=en-US
Thanks.
Ebele O.
(5,572 Views)
