VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Hello djroseman,
Can you verify that the drivers are correctly installed and configured for your device. Have you tried to reinstall the drivers yet?
Message 21 of 27
(5,065 Views)
Hello Michael,
I subsequently discovered that this error was caused by me having the VISA test Panel open on my device while trying to make VISA calls to it, connection then worked fine after closing it.
Message 22 of 27
(5,043 Views)
I have the same problem wih a Keithley sourcemeter, using both GPIB and USB connections. In the NIMax software everything seems fine but when running the example VIs this error appears.
Message 23 of 27
(5,034 Views)
I am using USB connection, but it also happened to me with GPIB. I solved the problem by changing the settings in my Keithley sourcemeter. The command set was TSP, and the problem was solved just by changing this to SCPI (check the picture). Now the labview examples for this equipment are working perfectly.
Message 24 of 27
(5,005 Views)
Can you suggest How to fix this errer : VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Message 25 of 27
(4,824 Views)
Yeah, give it sufficient location information, or hook up your instrument.  A generic question results in a generic answer.  The more details you can give us, the more tailored our answers get.  🙂
Bill
CLD
(Mid-Level minion.)
Message 26 of 27
(4,814 Views)
