VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
Perfect! now it works! Now I have some doubts about my VI, but at least I can send commands to my instrument. Thank you all  for your help! 😄
Message 11 of 13
(2,903 Views)
Hello!
  I want to know how you solved this problem?
Message 12 of 13
(2,836 Views)
Basically I was sending commands with bad syntax, that is without the space character /s (the command needs also termination character /n). Then the main problem was in the query I sent, because the commands I used works only in write mode, so during the read part it gave me an error.
Message 13 of 13
(2,775 Views)
