VISA: (Hex 0xBFFF0015) Timeout expired before operation completed.
I hope i don't get sue because copy right issue . I will capture the page later, the book title is Hands on Introduction to LabView by John Essick (even he give an example using 33 s for time out ). Anyway, i tried your vi and its not working either. Still get same error. I think my device doesn't understand command either because i tried it also using test panel and vi still not working tho.
Nb: currently my phone is dead so later i will capture it.
Message 11 of 17
(2,070 Views)
again timeout != delay.
here is a user manual for the device:
https://www.ujaen.es/departamentos/ingele/sites/departamento_ingele/files/uploads/medidor%20de%20lum...
page 38: describes usage with their software
page 36: describes how to use the device with a printer. You won't be using a printer but i'm sure you can extract data you need all the same, just use settings described there.
Can't find english user manual for the software T-A30, so i can't tell you what commands are accepted.
EDIT:
found the T-A30 user manual
https://www.yumpu.com/pt/document/read/19315705/t-a30-konica-minolta-sensing-americas-inc
Message 12 of 17
(2,065 Views)
Yes , Thank you for your additional information.
It similar with the third party that i contacted. I already change the setting with that databits , baud rate , etc. But the result same things.
Oh some one said which book i refer. Please see these attachment
Message 13 of 17
(2,034 Views)
I will check the video thanks gerd
Message 14 of 17
(2,031 Views)
Hi Gabess,
Ah, ok.
That old book talkes about voltage measurements using an Agilent34401 with certain settings. And it talkes about reading 100 voltage samples - and that's why it calculates a time of ~33s to read 100 samples at 20NPLC for a 60Hz power supply…
  • Why do you think yoou need to follow this calculation?
  • Do you want to read 100 samples?
  • Does your device some AutoZeroing for each sample? (Well, you could switch off that feature for most DMMs I came across!)
  • Does your device need 10NPLC to read one sample? (Most SCPI-capable DMMs allow to configure the NPLC parameter…)
Message 15 of 17
(2,027 Views)
Hi gerad,
1. I thought it was necessary to have that equation besides that i read other forum adding long time delay will be helpful for reading( which means i put 250s). Also, i thought when we using visa the procedure should be same isnt it ?
2. I think really want to communicate first with the device but in the future i would sampling the data per minutes .
3.it seems i read the manual and try the device Its not auto zero when he read luminance it will read continuously.
4.Im not sure about this, I will try to contact about the vendor about this related information . But the vendor said only mention that he has 150 NLPC
Message 16 of 17
(2,021 Views)
Update :  I tried to connect it with null modem, because i check it that konica minota rs232 is dce, so i decided buy null modem. Then, i tried it with NI MAX using same settings still cant read.
Message 17 of 17
(1,961 Views)
