VISA READ stops reading at 'zero'-char
I am reading a binairy message coming from an RFID tag that looks like this:
hex[01 09 0C B9 6E 53 0A 00 00 00 00 8B]
The Bytes at Port-property shows me the full message (12bytes) is present at the port.
Then I do a Visa_read with the 12 bytes as input, the read always comes back with 7 bytes read.
So the Visa_read stops at the ZERO characters...  In a subsequent read I take the other 5 bytes.
Why does the VISA_READ stop at the ZERO character?  (I am using XON/XOFF and the stop character is defined as 15, not zero!)
Check below code,
Thanks for help in advance!
(2,971 Views)
Accepted by _Xilinx_
Actually I bet it reads the 0x0A Smiley Wink and you have set-up the port with the following default properties:
  • End mode for reads= TermChar
  • Term Char = 0x0A
  • Supress term char for reads = True
If you check the error cluster out the warning will tell you that the term char was seen, There might be more data available...
Set up the port with a F wired to ternination character enable.
EDIT: Oh the jpg clearly shows I was rightSmiley Very Happy  make the T an F
(2,966 Views)
Exactly:manhappy: , I was shooting at the wrong character.
Thanks Jeff!
(2,960 Views)
