VISA Read continuous serial data drops packets...
They look like the are the same as the subVI's you posted back in message #1.  Did you fix them?  I described the problem you will have back in message #4.  If when you start your program, the first of the sync bytes isn't the next one coming into the buffer, you'll probably never synchronize with your message.  Crossrulz gave you a scenaro of how you should be executing these commands.
EDIT:  Attached a VI that implements Crossrulz's method.
Message 11 of 14
(1,465 Views)
I have a similar problem to this, have you solved the problem?
Message 12 of 14
(1,028 Views)
Hi M.z779243,
This forum you are posting on is almost two years old and may not get the attention needed. Please create a new forum post with your issue description and feel free to reference this forum for context. Thanks!
Jacob C.
Applications Engineering
Message 13 of 14
(1,008 Views)
okey thanks
Message 14 of 14
(996 Views)
