‎05-15-2008 03:25 PM
‎05-15-2008 03:47 PM
‎05-15-2008 04:20 PM
‎05-15-2008 04:33 PM
I think you are not reading the manual correctly. Everything I see says that address in hex only pertains to the RS-485 address. It is the address that is shown on page 24 of the manual and it explicitly says RS-485 only. On page B-2, the lead character for RS-232 is always CA and the Addr-LSB is always 01 for RS-232.
Now, if you need a programatic way to figure out which actual com port is connected to this and your other instrument, that is a different story but you do not have to change the hex value whether you have it connected to com1 or com99.
‎05-15-2008 05:01 PM
‎05-15-2008 06:06 PM
‎05-15-2008 10:08 PM
All you really need is two separate VISA Resources to communicate to two different devices. Use error in/error out connections tor control execution order.
This is a pretty generic question and without knowing a lot more about your requirements, it's hard to recomend a specific design pattern.
‎05-16-2008 02:52 PM
‎05-16-2008 04:04 PM
jesus.rp wrote:
I'm new to LabVIEW thus, maybe why i may sound more general than specific. I'm thinking in the general sense to understand better, sorry.
So specifically could you give me advice on what I need to change in the library files found here:
http://zone.ni.com/devzone/cda/epd/p/id/4515
Just for communication with the RTE 17? Forget the idea of 2 different hardware. Do I need to add a VISA I/O?
-Jesus
‎05-17-2008 06:04 PM
