VISA Resource name Select
Hi all,
I have a visa resource name select in my program that would allow me to select my GPIB channel.  When I click on the down arrow to select, it takes a long time (about 6s) for the options to show up.  Yes, some of the options are remote resources.  Is there a way to make the visa resource name select drop down box more responsive?  Thanks!
Yik
Kudos and Accepted as Solution are welcome!
Message 1 of 9
(6,220 Views)
I dunno - speed up the network?  If the resources you are interested in never change, maybe you can hardcode some constants and select from them instead?
Bill
CLD
(Mid-Level minion.)
Message 2 of 9
(6,201 Views)
Maybe there are some setting in MAX that I can modify?
Yik
Message 3 of 9
(6,168 Views)
The list can only populate as quickly as it can locate all of the resources, so as billko said, your bottleneck here is your network speed.
Well, probably not the speed of the network itself, but how quickly the resources respond to pings or whatever protocol is used to check their availability.
It is not anything in MAX that is slowing you down, it is how quickly the network resources are being located.
Cory K
Message 4 of 9
(6,159 Views)
Accepted by topic author jyang72211
Use visa find resources at the start of your program. That should work.
Edit: I said should work - let me know if it in fact does work!
LabVIEW 2012
Message 5 of 9
(6,148 Views)
Technically it doesn't speed things up, but moves the delay somewhere not so annoying.  It's a good compromise!
Bill
CLD
(Mid-Level minion.)
Message 6 of 9
(6,129 Views)
Nice!  Thanks!
Message 7 of 9
(6,117 Views)
hi im new in labview.. can ask some question regarding is using visa serial..
about the resoure name..does it automaticaly show the ports when i click the combo box?
or i just set up 1st or maybe type the name of the port? only refresh come.up..
Message 8 of 9
(5,973 Views)
If you place a Open Visa connection and Create Control it'll automatically scan, yes. You'll see the ones found/visible in MAX.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 9
(5,961 Views)
