02-10-2011 11:24 AM
What is the oldest version of Measurement and Automation Explorer that can be used with Windows7 32 bit? My USB-6009 is seen by windows device manager, but MAX 8.6 won't recognize it. Do I need a later version?
Solved! Go to Solution.
02-10-2011
11:42 AM
- last edited on
11-04-2025
08:36 PM
by
Content Cleaner
MAX comes with NI-DAQ. There is no MAX 8.6, you must mean the DAQ version. Check these charts for compatibilities:
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
02-10-2011 01:12 PM
Thank you for the charts, however I still need to know if this version of Max (4.3) and DAQmx (8.6) will work on Windows7 32bit. I'm having no luck recognizing my DAQ. I'm not even seeing it as a DAQmx device in "Devices and Interfaces"
02-10-2011
01:34 PM
- last edited on
11-04-2025
08:37 PM
by
Content Cleaner
02-10-2011 02:09 PM
In this post, Adnan (CLA) says you need to use DAQmx 9.0.2. Have you tried that, or just the latest version?
