VISA Runtime 18.5 Driver
Hi all,
I need to install VISA Runtime 18.5 on a laptop to run with a LabVIEW executable. The laptop is restricted so I'm not sure that I can install VISA in its entirety but I know that I will be able to install the runtime. Does the runtime include the drivers or do I need to install all of VISA?
(2,300 Views)
Accepted by topic author vrogers
You can just install the VISA Runtime.  I typically use the VISA Runtime With Configuration Support, which includes MAX and allowing you to use it to configure/test your VISA sessions.
(2,296 Views)
