VISA not showing COM port
Hello, I have made a simple VI which gets data from the PC com port.
It runs fine on my desktop but today for the first time I ran it on my new laptop and it is not showing the COM port. I can see the COM port in device manager but it does not appear in drop down menu in my VI. Can someone help please? I have attched my VI.
(4,108 Views)
Do you see it in Measurement and Automation Explorer?
(4,102 Views)
Accepted by Silencer
Are  you using labview 2013? I had a similar problem and I had to install NI-VISA for it to show up. So not sure if you have installed that, but if not, then that should fix your issue.
(4,077 Views)
I certainly hope the OP realizes that they need to install the drivers and not just LabVIEW when they want to use their VI's on a different PC.
(4,062 Views)
Thanks. That's exactly I was missing. It works now.
(4,029 Views)
