VISA read to listbox
I want to output the of the VISA read onto a list box and I need to store each of the values in the listbox on a new line. How do you suggest I go about it.
(3,567 Views)
Accepted by topic author sanath.j.bhat
Break up this task. Use a property node to write to the list box. This takes a string array, therefore you need to convert your data from the visa read function to a string array.
(3,561 Views)
What is the data type of the output of the VISA read function?
(3,552 Views)
Have you got labview? Have you looked at the help? Have you looked at shipping examples? evwn without labview you can look at the help online, just google it. You need to think how to convert the data you get to a string array. This will be based on the separator you expect from the serial device
(3,549 Views)
Thanks. I figured it out
(3,525 Views)
