VISA resource name-COM ports
Is there any setting for VISA resource name so as to configure it to display a list of only COM ports and not any other serial ports like LPT or GPIO INTFC?
(6,273 Views)
Hi mnx,
you can use VISAFindResource to get a filtered list of VISA resource names, it's context help describes all parameters...
I use "ASRL[0-9]*::?*INSTR" to filter COM ports.
(6,268 Views)
Hi GerdW,
Thanks for quick response..Smiley Happy
I was planning to do something with VISA resource name as with VISA find resource I need to keep on checking dynamically if user has plugged in any USB-serial converter on the fly and that will increase code complexity a bit..Also, I want to display ports as "COMx" rather than their addresses "ARSL.."
(6,259 Views)
Anyways, I am planning to implement the following code:
Just wanted to confirm if something of this sort is possible with VISA resource name settings?Smiley Wink
(6,256 Views)
There's some filtering available on the resource control. Check attached picture.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,233 Views)
