VISA resource name
Usually, under the diferent computers in between programming and operating,
I have had a problem to find some right RS-232 ports in a program where mutiple ports are used.
How can you recognize the right port mapping?
I got to know I can edit the VISA resource name in LV from someone's program.
How to map between real VISA port (RS-232) and user defined string?
Can  this be helpful to find the port in different computers?
메시지가 11-19-2007 12:22 AM에 labmaster에 의해 편집되었음
(3,573 Views)
I think you can use MAX to map every port in your PC  to a string name.
but you may not know the relaitionship between the ports and string names from someone's programme
(3,553 Views)
labmaster,
Thank you for contacting National Instruments.
I have collected multiple resources that I think will help you in your situation.
Please reference previous Discussion Forums: How is VISA resource name & COMport name mapping done? and Changing VISA resource names for controls to custom formats.
There are also many KnowledgeBase articles that have the information you are interested in. I hope these are able to answer your questions and also give you additional information.
Thank you and hope you have a great day.
Sarah S.
Applications Engineering
(3,433 Views)
