VPN connection
Hello everybody, I'm developping the monitoring system of water turbines. There is CompactRIO and PC at the powerplant. I want to open VPN connection, run the application in my office and read shared variables from the powerplant. Labview have any function to open VPN. But it could be done via Windows command line. Do you know how I could send command from Labview to command line and open VPN? And after close the application to leave VPN?
Message 1 of 11
(49,422 Views)
Do you mean open the VPN connection to access the Office network from home?
Message 2 of 11
(49,391 Views)
Well, I've done it already.
I've used System exec.vi and I've connected to command line input the string: rasdial "VPN name" user password. To disconnect I've used string: rasdial "VPN name" /disconnect.
It works very well 🙂
Message 3 of 11
(49,349 Views)
Having a VPN user name and password in plain text as source in an application would make any IT professional a little nervious.  I'm hoping for their sake that passwords expire every 6 months or so.
Message 4 of 11
(49,279 Views)
I did the same thing using rasdial.
Is there a way to enumerate VPN name?
George Zou
Message 5 of 11
(47,789 Views)
Hi zou,
You can write the vpn name string array into the String[] property of a ring.
Message 6 of 11
(47,768 Views)
Thanks for reply.
But I don't know the VPN name on users computer.
I want to find a list of VPN connections configured on the users computer.
George Zou
Message 7 of 11
(47,764 Views)
If you are using win 7 or later and have powershell, try this command in command prompt:
powershell Get-VpnConnection -AllUserConnection
Message 8 of 11
(47,757 Views)
Thanks.
It seem the command is not recognized by powershell:
George Zou
Message 9 of 11
(47,752 Views)
Maybe your powershell is of older version or is missing the vpnclient module. Did you try using the latest version powershell?  I'm not really familiar with powershell so I'm not sure. I think this question can be asked at the microsoft forum.
Here is the information on this command.
Message 10 of 11
(47,746 Views)
