VTEDS
I downloaded Create Virtual Teds.llb.
I found no Microphone Template . How do you get them?
Please provide specific examples.
Excuse me for my poor English!
" 一天到晚游泳的鱼"
labview@263.net
我的个人网站:LabVIEW——北方客栈 http://www.labview365.com
欢迎加入《LabVIEW编程思想》组——http://decibel.ni.com/content/groups/thinking-in-labview
(2,945 Views)
Accepted by flim21
From my research, I assume that you downloaded the .llb file from Creating Virtual TEDS
1.  Apparently the code developer did not include the microphone part.
2. By referring to other templates available in the .llb file you can create microphone template on your own easily.
Please refer to IEEE 1451.4 Sensor Templates Overview
Fiona, NI
(2,886 Views)
Accepted by flim21
In LabVIEW, there is a subpallete from NI-DAQmx where you can access TEDS functions. , The TEDS library and templates are usually available In LabVIEW 2018 and later versions there is no need to install them again.
1. If you need to install them please refer to this link How Do I Install The TEDS Library into LabVIEW?
2. To learn how to use TEDS functions you can refer to this link Using TEDS With NI-DAQmx in LabVIEW
Fiona, NI
(2,847 Views)
Thank you for your reply! I will keep on learning! Try it!
" 一天到晚游泳的鱼"
labview@263.net
(2,845 Views)
You're welcome~
(2,836 Views)
