timed loop and processor load
I have a problem of occupation of the processor load by a timed loop: - I have a loop clocked at 100ms - the content of the loop takes a little less than one ms to execute - launching the vi containing this loop increases the CPU load from 10% to 20% !? I Have other vi loaded in the same time of this one. In particular some vi which manage the sending of RS485 frame all of 10ms (with timed loop too). I have well isolated the problem on the timed loop. In the timed loop there is an FGV type VI which is well configured (not "reentrant") I have no idea of what can cause it .......i have made a lot of test and .....i dont understand! i have other timed loop vi ...and they take just 1 or 2% of processor load......
Thank you! Regards,
(1,601 Views)
Hi doublevprint,
replace the TimedWhileLoop by a simple While loop with a 100ms wait function inside…
(1,594 Views)
