09-15-2010 05:04 AM
I need a VXI that has
1) signal generator slot with frequency range: 80MHz- 500MHz signal level -10db to +10 dB (CW).
2)spectrum Analyser slot that has the output measurement upto 50W. Power supply logging i.e, voltage and current.
is this available with NI.
09-15-2010 10:36 AM
NI does not make any VXI instruments. In the past, I've used VXI from Agilent and Tektronix but they no longer make anything. The VXI product lines were sold off or closed due to lack of sales. It seems that the trend is to use PXI. Besides using Google, you can try VXI.org. They have a product list.
