Value Pairs
I'm still having problems. I cannot find in PropertyNode references necessary for me.
Message 11 of 17
(3,225 Views)
Message 12 of 17
(3,221 Views)
Hey Ravens,
I saw that at first too, but it does not add values. With a mix of property nodes and onvoke nodes, I found out how to do it.
Message Edited by Chris_VH on 04-16-2009 03:27 PM
Chris Van Horn
Applications Engineer
Message 13 of 17
(3,213 Views)
Accepted by _Pavel_
Big thanks!
But in LV 8.5 I'm have next.... And, I'm still having problems...
Message 14 of 17
(3,196 Views)
After the CWAxis3D property node (ValuePairs) you need to wire in an invoke node. Works in LabVIEW 8.5.1.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 15 of 17
(3,181 Views)
Its an invoke node, not a property node. Same pallete, but notice the difference in the nodes with a wrench and the node with an arrow.
Also, you want to use accepted solution for the post that answers your question, not your own post saying you still have questions.
Message Edited by Chris_VH on 04-16-2009 04:34 PM
Chris Van Horn
Message 16 of 17
(3,180 Views)
Chris_VH wrote:
Hey Ravens,
I did this and it worked for me.  After I ran the VI, that information showed up in the 3D graph properties dialog box.
Message Edited by Ravens Fan on 04-16-2009 06:19 PM
Message 17 of 17
(3,168 Views)
