Value Property Node for an array element: how do they work?
As I was vainly trying to make sense of my recent mistaken Idea Exchang submission (here), I stumbled upon a behavior I am not sure I understand.
Here it goes:
Drop an array of numerics on the FP. Show a few elements. The easiest is to grab an "Array - Numeric (Silver)" preformed object, with 3 elements shown.
Now, right-click on the top element and select: Create>>Property Node>>Value
Change that to write on the BD and connect a constant to it, say 1. Run the VI, you get this:
Screen Shot 2014-07-30 at 15.11.50.png ===> Screen Shot 2014-07-30 at 15.12.00.png
So far so good.
Now do the same for the THIRD element and wire a different constant to the PN, say 3. Run the VI again, you get this:
Screen Shot 2014-07-30 at 15.13.29.png ===> Screen Shot 2014-07-30 at 15.13.39.png
All right...
I mean, it already doesn't make much sense, but wait for what's coming...
Now, delete the first PN and rerun the VI:
Screen Shot 2014-07-30 at 15.14.40.png===>Screen Shot 2014-07-30 at 15.14.49.png
Perfectly logical, right? ... not!
At least *I* can't make sense of it and this smells like a bug to me... or a weird feature.
Tested in LV 2013 SP1 (62+2 bits) on Windows 7 64 bits.
Message 1 of 14
(7,577 Views)
Accepted by topic author X.
You are creating a shortcut to write to the ArrElem.Value property.  The ArrayElement property of an array is a bit funky, it is the last element which has been active.  With only a single PN on your BD writing a value, click in the middle element of the array and then run the VI, repeat for other elements.
Message 2 of 14
(7,558 Views)
In the second picture, you didn't enforce the data flow, so the 3rd item in the array (the active one) got set to 3, and then set to 1.
If you enforce the data flow, it looks different.
You will get 3 instead of 1, if you wire like this:
George Zou
Message 3 of 14
(7,552 Views)
As Darrin said, it just matters which element is considered the "active" element.  So in your second example, you actually wrote to it a 3 and then a 1 (classic race condition).  You can set the active element with a property of the array (having trouble finding it at the moment).
Message 4 of 14
(7,551 Views)
Makes more sense now (@Zou: I had actually noticed what you illustrate, but I had not try to figure out the reason yet).
This being said, how do I know which element is active programmatically?
Message 5 of 14
(7,545 Views)
You get the bounds of the ArrayElement, do some math based on the bounds of the array control taking into account the value of the index display. Easy peasy eh.
Message 6 of 14
(7,532 Views)
The bounds I can get are those of the Array, even if I pull that from a reference to an element.
The only way I can figure to get the Mouse Click location and indeed compute the array element based on some arithmetic.
Other suggestions?
Message 7 of 14
(7,527 Views)
Put a listbox behind it.
Make sure the row height same.
use the listbox invoke node: point to row, to get the active array index in the mouse down event.
George Zou
Message 8 of 14
(7,519 Views)
@zou: that's a workaround.
My point is that we get this nice Last Active Element Value PN (Read and Write) but we essentially are left to guess (or work out) which it is. That's fine, but it would seem natural to have some helpers there, such as an "Index of Last Active Element" PN, for instance.
Message 9 of 14
(7,509 Views)
I actually meant to suggest the ArrayElement.Position property.  I am pretty certain that one works for the individual elements (I kind of assumed the bounds would as well).  Not that I have undertaken this in a long, long time.
Message 10 of 14
(7,493 Views)
