Value (Signaling) property and programmatically generate value change event?
I need to do exactly what Frans wanted to do.
So 6 years on, is there an event based (non-polling) method to have an ActiveX client (to a LabVIEW ActiveX EXE server) do the equivalent of setting the value signalling Property of a control on that EXE's FP?
rgds
Message Edited by Peter_B on 05-27-2010 12:58 AM
Peter
Message 11 of 16
(2,581 Views)
I guess not.  So my chosen solution is to write a vi which grabs a reference to the desired control and sets the Value Signaling property of it.  This vi will be called from my C# .NET code via the ActiveX method   object.Call([paramNames], [paramVals])
There is a great example here for how to do thism just scroll down to the bottom and click on callinglvcsharpusingactivex.zip
rgds
Peter
Message 12 of 16
(2,550 Views)
Perhaps what you are after is a callback.  Here is a page referencing .net but I think you can use them with active X as well.  I have used them within LabVIEW itself instead of polling.
http://decibel.ni.com/content/docs/DOC-9161
Craig
here also is doing it with activeX http://digital.ni.com/public.nsf/allkb/292FA0C0E7A0D69B86256D18007F525E
Message Edited by craigc on 02--06-2010 10:42 AM
LabVIEW 2012
Message 13 of 16
(2,538 Views)
Thanks Craig.  I considered using an Event callback and got most of the way to implementing it in C# until I realised how much simpler it is in both programming environments to do it the way I mentioned above.  I was already communicating to the LabVIEW ActiveX EXE server from the C# environment, so it seemed a logical and simpler way to solve the problem.  Events in C# require too much coding compared to using the ActiveX call method I highlighted above.
rgds
Peter
Message 14 of 16
(2,529 Views)
Can some one please help me with what is the correct method to call
SetControlValue method so that respective change event triggers automatically ?
Message 15 of 16
(1,437 Views)
I don't think that is possible using the Method (Control Value Set), instead write to the Value Signaling property.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004BKFSA2
You can also do this in a sub vi by passing a reference to the control into a generic property node and selecting Val(Sgnl)
Peter
Message 16 of 16
(1,423 Views)
