Values of Boolean Array to dictate output to be Boolean False or Boolean True
I have a fairly simple question that I'm having an issue with solving.
I am looking to input a Boolean array to a sub-vi that will take that array and dictate a single boolean output to be Boolean False or Boolean True.
For instance, the array will be 1D boolean array, with a depth of 2 index values.
-If both index values are False then the sub-vi will kick out a False value.
-If both index values are True then the sub-vi will kick out a True value.
-If one index value is True then the sub-vi will kick out a True value.
Any ideas?
Thanks.
(3,487 Views)
Accepted by topic author jonathanupr
That sounds like an OR to me
I'm not sure what you mean by this.  How are you choosing the indecies to use?
EDIT:  Maybe you need the OR Array Elements
(3,484 Views)
The 1D array will only have 2 values.
(3,479 Views)
The "Or Array" function works great.
Thanks for the quick response.
(3,474 Views)
Yep, the OR Array elements is what you want.
(3,473 Views)
Then please mark Crossrulz's post as the solution to your question and not your own message.  First you will need to go to the options menu to the upper right of the message you marked as the solution to Unmark Solution.
(3,470 Views)
