save 2 pictures in one picture
hi,
i want to save the image of 4 graphs into one png file. i put  the images of graphs 1 and 2  in one file(untitled.png) and  the images of graphs 3 and 4  in another file(untitled1.png).then,i try to put untitled.png and untitled1.png in one file(untitled2.png) an error occur as seem in the save4graphstogether.vi.
anyone can help me plz
(2,750 Views)
Is the error you are talking about the broken wire coming out of the last Build Array function?
If so, try turning on the Concatenate Inputs option in the right click menu of that function.  Right now you are taking 2 2-D arrays and creating a 3-D array.
(I don't see the point of writing pictures out ot a file to immediately read that file back in again.)
(2,742 Views)
yes the error is the broken wire,
i try turning.....but the error still 😞
(2,727 Views)
Right click on the Build Array node (it is right before the broken wire).  Pick "Concatenate Inputs".  Now the broken wire will be fixed.
(2,724 Views)
thanks,al is ok
(2,717 Views)
