Variance for a set of real time data
I am continuously acquiring a set of sensor data through LABVIEW with a sampling rate of 100Hz (100samples per sec). What I want to do is to find the variance of the set of data every 0.1s. Im collecting the acquired sensor data into a 1D array "SensorData." Then wat I want to do is each time 10 new samples are collected, I want to find the variance. I tried using the variance ptbypt but it always outputs a value 0.0
Your help is greatly appreciated.
Thanks!
Chathuri
(3,374 Views)
Accepted by Chathuri
What is the sample length you specified in Variance PtbyPt vi? Did you check the initialize condition?
How exactly you are calling this subVI?. To get a variance output of 0.1 second, you might want to set your sample lenght to 10.
Could you post a VI which shows this value?
If you are seeing 0.0, try to expand you numeric indicator, there might be an exponential value at the end :smileywink:
(3,365 Views)
Yes, I feel so stupid. I left the indicator to display values of 2 decimal places. I increased the significant digits and now I am getting a value 🙂 Thankyou!
Chathuri
(3,362 Views)
And I thought I solved your problem. :smileymad:
(3,356 Views)
(3,341 Views)
Oh I was right!! :smileyvery-happy:
(3,339 Views)
