Variants: How to assign a new value without altering/losing its attributes?
I'm working with variant data with some metadata stored as attributes. The data values change frequently, but the metadata values are fairly constant.
I'm looking for a way to update the value of a variant while preserving its attributes (or equivalently, transfer the old attributes to a new variant). I know I can read the attributes from the old variant and insert them into the new one, but I'd imagine that doing this for many variants in a tight loop is wasteful of CPU cycles -- is that a valid concern? Is there a cleaner way to do this?
Thanks!
Certified LabVIEW Developer
(2,952 Views)
Use the "in place element structure" with the "variant to/from element border node". Seems to leave the attributes intact while changing the value of the variant.
(2,941 Views)
Accepted by JKSH
Here's a quick and dirty example:
(2,935 Views)
