Verify Ethernet connection
I've had that experience before and usually it is caused by having the firewalls settings turned ON.  Have you tried turning the firewalls off? Also, check if you have any anti-virus on.  You may need to turn it off or add an exception to that port.
Message 11 of 19
(1,474 Views)
I'll try, thanks!
Message 12 of 19
(1,470 Views)
Message 13 of 19
(1,465 Views)
firewall are off..any other idea?:)
Message 14 of 19
(1,464 Views)
Message 15 of 19
(1,461 Views)
yes, I was exactly trying that link..but I can't find 'device and interface' in MAX...
Message 16 of 19
(1,452 Views)
Do you have the NI Drivers installed?  You might need to re-install the drivers and Measurement and Automation.
Message 17 of 19
(1,450 Views)
I did thanks! now I can see the devices but I can't connect to it..driver missing...but this is an object made specifically for us..don't know..thanks for your help though!
Message 18 of 19
(1,444 Views)
Dear all..here we are again.The camera is connected but I still can't see any data. I attach here the diagram of the .vi, From the instructions I have to:
1)Obtain instance of the Synchronous.Otb.Camera by calling the constructor
2)Call Camera.Start()
3)ensure Camera.LastOperationErrored returns FALSE to show connection ok
I did these thing in the first case.
Then
1)Determine capture period and oversample rate
2)call Camera.CaptureImageLine passing the capture period and oversample rate in the actual parameter list
3)Ensure Camera.LastOperationErrored returns TRUE to show connection ok
4) Read Camera.ImageLine to obtain the value of each pixel.
Could you please tell me what you think?
Thanks!!!!
Message 19 of 19
(1,430 Views)
