Version 8.5 switches to front panel unexpectedly
Yes, but only because LV programming is a very small fraction of my work.
Message 11 of 24
(1,674 Views)
AE Charlie- I upgraded to LV 2009 about 3 months ago and the problem persists. Upon clicking on something in the block diagram the view switches to the front panel. Unrepeatable, but always requires a mouse left click.
Message 12 of 24
(1,610 Views)
This issue is pretty bizarre. I have not seen anything like this!!
Does the front panel and block diagram switch when you're not clicking or interacting with any controls or indicators?
Does this happen when you try different input hardware, such as the track pad instead of the external mouse?
How many computers have seen this behavior on and how different is the hardware?
Do you have other programs that require a double click to make a drastic enough change to notice?
It might be interesting to mess around with the double click speed, or just switch it of for testing purposes!
Do you have any programs that relate to switching windows (or editing monitor properties), such as multimon or Vista switcher?
What OS are you using?
Aashish M
CEO
TransferFi
www.transferfi.com
Message 13 of 24
(1,582 Views)
As I said in the beginning of the post, this has been a problem with LV8.5 for years on both my pc and a colleague's pc. We both upgraded to Labview 2009 and I still have the problem but he hasn't used his LV since the upgrade. I'm using an IBM T60 laptop and he's using an IBM desktop pc. It also occurred with my previous IBM laptop, a different model, maybe T54? No, this problem does not occur on any other application and I have many. No, there is no switching to front panel if there is no mouse clicking. Only occurs on a mouse click- sometimes on a wire, or menu or other item, not necessarily a front panel control or indicator. Haven't tried using a trackpad. I'm convinced this is a Labview problem and not an equipment problem. I don't see how double click speed is involved. I'm not getting double click results with a single click. I don't have multimon or Vista switcher. My OS is Windows XP Professional. I would really like to solve this problem because it's getting to be a problem with my productivity. I upgraded to LV2009 in December and saw no problem until early February, when I modified a type def and the problem immediately began again. I found in one case I was working on the block diagram of a SUB vi, and upon a mouse click the MAIN vi front panel window opened.
Message 14 of 24
(1,562 Views)
Were there any differences using the track pad?
Have you entirely changed the hardware from the older computer set up to the new one? Were there any constants, such as a mouse or keyboard?
How many different keyboard or mouse combinations have you tried?
By any chance, do you have a video that displays this behavior?
I believe the best way for me to get a full picture of what is happening, is to see a video of the actions that you have been performing.
Aashish M
CEO
TransferFi
www.transferfi.com
Message 15 of 24
(1,517 Views)
Thank you for trying to help Aashish_M. I have not tried using the track pad, but I may try it. I have not tried another computer setup, however another Labview user with a desktop pc has seen the same problem. I have consistently used the same mouse and keyboard. There is no way I can make a video of my programming. Maybe the best I can do, if it helps, is make a list of mouse clicks that trigger the change to front panel.
Message 16 of 24
(1,502 Views)
Ok, so it might sound like I am blaming your hardware here, but I am just really trying to narrow down the issue as much as possible. I think it would be a good idea for you to provide me with specific instructions to reproduce the issues you are getting.
The first thing I would like to eliminate is the hardware changes and pretty mush any possible descrepencies here.
1. Can you please remove any user input based devices on your laptop?
2. Could you check through all the programs that are running in you computer and make sure there's nothing that react to user based inputs?
The second step would be to analyze and isolate the software issues.
1. Please provide the main actions that reproducible on every attempt that causes the issues you are facing.
2. Check if VI Server is active. If it is active, please disable it. I don't know your fellow employees, but there could be someone playing tricks on you Smiley Wink (unlikely the cause)
Let me know if we get anywhere with these attempts to narrow the issue down.
Kind regards,
Aashish M
CEO
TransferFi
www.transferfi.com
Message 17 of 24
(1,484 Views)
Ok, I'll see if I can answer your questions. First, what do you mean by "user input based devices"?  Therefore I don't understand your second question about programs responding to "user based inputs".
As I described before, when the event occurs, the mouse click that caused it will not cause it repeatedly after that. It's totally unpredictable when it happens and what causes it. The only exception is the past few days there has been some consistency. On June 2 I clicked Edit>Undo Move and it caused the change to front panel. On June 3 that same sequence caused it 2 times, but not in succession. I cannot do Edit>Undo Move and make it happen. Normally the transition occurs on almost any mouse click such as selecting an object.
I don't have a "vi server". All my vis are on my hard drive.
Message 18 of 24
(1,467 Views)
Here are some more events that trigger the switch to front panel and when they occurred:
6/2/10
Click Edit>undo move
6/3/10
6/4/10
Click to terminate new wire
6/7/10
Ctl-b to remove broken wires
The last one is not consistent with my statement that it always occurs with a mouse click.  Anybody have any clues why this is happening?
Message 19 of 24
(1,431 Views)
A mouse and keyboard are examples of user input devices. I just wanted to eliminate these initially. Have you managed to work with your laptop without the external mouse and keyboard? Did it make a difference?
I will try out the mouse events to see if I can reproduce this.
Aashish M
CEO
TransferFi
www.transferfi.com
Message 20 of 24
(1,395 Views)
