Version NI VISA runtime engine to install?
Which version NI VISA runtime engine should I install? Are they tied to a specific version of LabVIEW?
I see that the latest is NI-VISA 15.0.1. I am using LabVIEW 2013.
(4,814 Views)
Accepted by topic author stephenb2
You should be fine with that combination.
Look at https://www.ni.com/en/support/documentation/compatibility/16/ni-visa-and-labview-version-compatibili...
But my question is are you really trying to install a NI-VISA runtime, or the full NI-VISA driver?  You generally only install a run-time on a machine that is not going to have a development system and only going to have an executable you built in LabVIEW on a different development PC.
(4,807 Views)
Thank you. That was the information I was looking for. It's primarily a runtime environment, but for the times it isn't I'll install the full environment.
(4,785 Views)
