random numbers - simulate a dice
i found that "random number 0-1" feature in Labview, but how about
simulating a dice (1-6).
Best regards
f.pöck
Message 1 of 19
(14,249 Views)
Hi
That's just simple math:
Let's say x is a random value.
So you get dice = 1 + round(x*5)
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 19
(14,231 Views)
Try the attachment.In the select tool true condition give your choice of number for to avoid getting zero.
by,
Kumar
Message 3 of 19
(14,229 Views)
Just multiply by 6 and round to the next highest integer.
Choose the output that you want for your needs, integer or double.
Random is strictly between 0 and 1, but you might possibly want to make sure that rounding errors in the multiply haven't made the answer 7.
Rod.
Message Edited by Rod on 08-10-2006 12:16 PM
Message 4 of 19
(14,223 Views)
Hey,
One more method, only if your are not particular about 64 bit Float (dbl) data representation of random number generated
Message 5 of 19
(14,222 Views)
Errm, but if you multiply by 5 and convert the result to an integer, doesn't that give you a fencepost error??
Depending whether your conversion is to the integer above, below, or nearest you'd get no instances of 1, no instances of 6, or get 1 and 6 half as often as 2, 3, 4, or 5.
Rod.
Message 6 of 19
(14,208 Views)
Yes Rod, that will also be a concern
Message 7 of 19
(14,200 Views)
Best regards
f.pöck
If you multiply by 6, round down and add 1 you get the required result.
The attached VI (LV7.0) shows that the distribution is even between the 6 numbers.
Tim Norris
"...and all this science I don't understand
it's just my job five days a week"
Using 6i, 7.0 & 7.1 on Win'98, 2K & XP
Message 8 of 19
(14,157 Views)
See the attached example for multiple dice rolls simulated
Paul
LV 7.0
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 9 of 19
(14,139 Views)
Oops no attachment, here you go!
Paul
Paul Falkenstein
Message 10 of 19
(14,138 Views)
