Vertex array variables
I'm working on displaying a grid on a 3D display and would like to utilise variables that you can change on the front panel to change the dimensions of the grid. Problem is i cant put any of the variables into the vertex array. I've posted a picture below. this is my first post so sorry about any format issues.
Message 1 of 9
(4,229 Views)
Your problem description isn't clear.
Does that mean the grid is 3 dimensional ?
The vertex array is the grid ? And the variables are the sizes of each dimension of the array/grid right ?
So why do you want to insert (put) the sizes in the array ?
All I see arrays of cluster of 3 DBL. Why is there 3 times the same constant ? I suppose the control is the same type as the constants.
What I imagine you want is : resize a 3D array of numbers (DBL) with controls on the front panel. Am I right ?
Yddet
Message 2 of 9
(4,199 Views)
To make it more clear I've got a 3D object displayed on the front panel and i would like to automate the a grid creation process to show its position in the XYZ axis through the use of a loop. I would like to have the user input 3 variables for the length, width and depth of the area and have a grid span only to that area. I've included more in-depth pictures below, sorry for the vague question. I've made a bit of progress since but still a work in progress
grid creation
manual input grid that i made earlier
This is where i put the data in for the manual input, i need to somehow generate 2 separate vertex points and put them into this 1D array which is the crux of my problem.
Message 3 of 9
(4,194 Views)
Hi Earl,
When you want to "add" elements to an array you can use BuildArray (in concatenation mode) to add at array start or end. Or use InsertIntoArray to "add" elements somewhere into the array…
On your code image:
Why are there backwards wires?
Why are there coercion dots?
Why do you try to insert into an empty array?
Why don't you attach the real code? (We cannot debug images in LabVIEW…)
Message 4 of 9
(4,177 Views)
Hi
Thanks for the help, I've only just started with Labview and i haven't had much practise with arrays yet. There are backwards wires because this is only a section of the code i want to work on and i didn't think the rest was relevant (ive included the rest below but its still a work in progress).
I didn't even know what coercion dots were before you pointed them out but they'er there because the double and integer values are being divided. Should i rather use a double to get rid of the coercion?
Do you mean i should be entering in values into an empty array ?
Thanks for the advice
Message 5 of 9
(4,151 Views)
The more concerning coercion dot is the one on the green wire going from the subVI to the Drawable input of the SceneObject property node.
Message 6 of 9
(4,144 Views)
Hi Earl,
I haven't seen this in the image posted with the first message.
I was concerned about the coercion dots at the BundleByName function: why are there coercion dots when all the constants around this function are under your control?
Message 7 of 9
(4,122 Views)
Accepted by Earl_Toucan
Hi Earl,
I couldn't open your VIs because I don't have the latest version of LabVIEW but this might help
It will not do exactly what you want but it shows how to build an array of cluster with a variable size. You will probably want two FOR loops inside this one for the other dimensions
Yddet
Message 8 of 9
(4,108 Views)
I got it to work by using 2 for loops for each axis then bundling the values and inserting them into an array,I've included my solution below in case u want to see. Thanks for all the help 🙂
This is an extra side note but does Labview support a render distance function as if i make a large grid i tends to slow down the simulation ?
Message 9 of 9
(4,094 Views)
