Very awkward - indicators turned black
Hello a have an application that was running smoothly and now all the indicators are black. Does anybody have a sugestion?
Thanks in advance.
Message 1 of 12
(4,089 Views)
Find>Property nodes.
One of them will be a buggy version of:
Somehow Text.BGColor is being set incorrectly (hmmmmm Black is the default colorbox constant value) You could also search for colorboxes!
Message 2 of 12
(4,074 Views)
Accepted by topic author AlexandreHSCastro
Try to find out which color was selected in the first place. Aside from directly  defined RGB values you also have system colors (for Window ...) If someone changed your color scheme these may change as well. I had a problem while deploying an exe to a PC with different colors resulting in grey on grey indicators.
Gabi
7.1 -- 2013
CLA
Message 3 of 12
(4,048 Views)
Your statement seems to imply that this happened all at once.  You might also check to see if the system settings on the machine you are using is the same.  Sometimes the use of theme matching colors can cause color changes.
Just a thought,
Jason
Wire Warrior
Behold the power of LabVIEW as my army of Roomba minions streaks across the floor!
Message 4 of 12
(4,026 Views)
Yes in fact it happened all at once.
I'm going to check the system settings and the windows fonts.
Thanks Jason...
Message 5 of 12
(4,019 Views)
I have no property nodes linked to those strings indicators. 😞
Thanks anyway Jeff.
Message 6 of 12
(4,017 Views)
I guess u might be on to something here:)
System settings, or color scheme or even system fonts...
Thanks Mighty Wire Warrior.
Message 7 of 12
(4,016 Views)
Maybe your monitor ran out of that color. Have you checked to see if the LCD color cartridge is empty?
Message 8 of 12
(3,999 Views)
LOL Smiley Very Happy
Nice one smercurio!
May a should accept as Solution :).
Thanks for making me laugh on this sunny afternoon:)
Message 9 of 12
(3,988 Views)
Smiley Very Happy
"LCD color cartridge"  That's funny!  I will use that.
Wire Warrior
Message 10 of 12
(3,985 Views)
