Vi Freezes upon Trying to Edit or Select
I am trying to edit a VI. Upon trying to delete or select a command with I/O Assistant 1 (the first write command) the computer freezes. Everytime I try to delete this command or commands below it the computer freezes. It seems to be a software bug. I have tried deleting the I/O Assistant and starting from scratch but I don't have enough skill yet in VI writing to do this. Any help would be appreciated.
Nevica
Message Edited by nevica on 07-30-2009 05:53 AM
Message 1 of 9
(3,480 Views)
I don't have any problems deleting in the VI, neither wit LV 7.0 nor LV 8.6.1. This could be a result of my multi LV machine having a newer DDL or driver the I/O Assistant is using.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 2 of 9
(3,466 Views)
How can I check for latest drivers?
Message 3 of 9
(3,463 Views)
Do you see a red rectangle encapsulating your vi? You have to remove the break point. You can also copy the whole code and create a new vi if you arew not able to clear it
Message 4 of 9
(3,445 Views)
Hello Muks,
Thanks for your advice. Unfortunately, that won't help as this problem might recur again and I am just wasting time if I have to start the vi from scratch. I would like to get to the bottom of why the vi freezes when I try to edit or delete a command.
Nevica
Message Edited by nevica on 07-30-2009 07:54 AM
Message 5 of 9
(3,440 Views)
Message 6 of 9
(3,436 Views)
Hello Muks,
Unfortunately i am only using LabView 7 and the file won't load.
What did you want to show me.
Nevica
Message 7 of 9
(3,433 Views)
He just removed the breakpoint on exit of the VI. Unfortunatly he saved it in the wrong version.
The I/O Assistant is using NI-VISA.  You can check for newer drivers on the Drivers and Update page.
Waldemar
Message 8 of 9
(3,417 Views)
Accepted by topic author nevica
Yes and hopefully someone can change it to lv 7.0.
Message 9 of 9
(3,391 Views)
