Vi as dialog
hi,
How can i make a vi and use it as a dialog.
Can u tell me how to do this in labview?
Thanks in Advance
Regards
Soundarya
(3,264 Views)
The help files are quite useful, here is what I found for LabVIEW 8.6 and LabVIEW 7.1.
Hope these guide you to making a dialogue box.
(3,261 Views)
Hi Soundarya,
this is the 3rd thread of you on "dialog windows". When you were asked to give more information you didn't answer but create a new thread...
Please stick to one thread when it's on the same topic. This will greatly help others to follow the discussion and to get the full picture!
(3,243 Views)
Yes, you can make a dialog window with VI. Just start with the Dialog VI-template or the Dialog with events template. The window will be a modal window and has some slightly other colors. Regarding the question in one of your other threads: A VI that is not running isn't doing anything. Of course you can enter data in the Controls but the data is not process. Why are you asking? Please specify your aim.
(3,223 Views)
You can make a VI as a Dialog by way of File >> VI Properties >> Window Appearance category.
- Partha ( CLD until Oct 2027 🙂 )
(3,215 Views)
