regarding dialog boxes
I need to add various VI's to my empty project in labview. Is there any way adding a dialog window same as we do for adding a VI to the empty project.
So when ever i press any button, the dialog window should open.
Is it possible to do this in Labview?
                                                            Thanks in Advance
Soundarya
(3,192 Views)
Hi Soundarya,
you can add every file type to your project.
What do you mean with a dialog window? Which file format is it? Do you mean an OS dialog?
Can you explain or show an image of it?
Mike
(3,180 Views)
continued here...
(3,170 Views)
Confusion all over with so many threads on the same topic by the same person.
(3,154 Views)
