Vi front panel portion blacked out.
I copied my vi from laptop and opened it in desktop which has large size monitor, I see that vi front panel has a blacked out portion in the bottom. How do I correct it. The screenshot is attached.
Message 1 of 10
(3,131 Views)
Hi msabah,
attaching an image of code instead of the code surely prevents us from editing&debugging that code.
That being said:
  • Using a JPG with lossy compression can hide details due to compression artifacts. What should we see in this screenshot?
  • The context help mentions a subpanel: is there a subpanel on your frontpanel?
  • Is the frontpanel backgorund color set to black, with a subpanel in the upper left part of the frontpanel!?
Message 2 of 10
(3,102 Views)
What happens if you resize the front panel? Will the black go away? Is it just a glitch or is it like that always? Are you setting the size programmatically? Without code, we can only guess.
Try adding a splitter bar and see if it changes.
Certified LabVIEW Architect
Message 3 of 10
(3,079 Views)
I have attached the VI, VI may be broken, but I only need the gray portion Subpanel to occupy the whole screen.
I have not made the front panel background as black.
Message 4 of 10
(3,073 Views)
Hi msabah,
When you resize the window/frontpanel you also should resize the subpanel container when it should "occupy the whole screen"!
You may do this using context menu settings ("Fit to pane", "Resize with window") of the subpanel or programmatically using property nodes…
(I cannot open your VI due to its LabVIEW version. Mind to attach a downconverted version for LV2017?)
Message 5 of 10
(3,070 Views)
I am attaching the LV 2015 version copy of my VI for your reference.
Message 6 of 10
(3,059 Views)
Hi msabah,
Now I can open the VI.
I see the default gray frontpanel background and a subpanel, which adapts to pane size.
I guess you already implemented my suggestions before saving that VI?
Message 7 of 10
(3,053 Views)
I have not changed the vi. try to open the vi in a 21 inch monitor. The black portion appears at the bottom.
Message 8 of 10
(3,050 Views)
Hi msabah,
I don't have such a monitor available, I use a 15" laptop right now.
But I could scroll the window (after enabling scrollbars), change the subpanel size, move that error cluster without ever noticing any black background color…
Maybe it's a problem of your computer, like graphics card driver?
Message 9 of 10
(3,044 Views)
I cleaned up your VI so it could be run and it works here, on 3440x1440, LV2020 SP1. I do see that when the VI is resizing, the parts that are outside the FP first for a millisecond are black, before the resizing is done.
So, as GerdW suggests, it is probably graphics driver related. Maybe you can try on another PC.
Message 10 of 10
(3,036 Views)
