View an ActiveX object contents
Is it possible to view an ActiveX object contents ? I'm working on MGMotor Control ActiveX object and I wanted to know how it's working inside.
Thank you.
Che57
(2,866 Views)
If the question is, can you see the code in it? The answer is no. ActiveX objects are compiled so the source code is no longer available. If the question is can you see the properties associated with the object, the answer it yes, and you would use a standard property node to get at them.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,844 Views)
