12-10-2012 01:58 AM
hello to all,
i have to build a mask for a signal and check if the real signal stay in my mask range...
in what way can i build it?
for example: i have as input a square waveform -2V,+2V, f=1 KHz
my range in +/- 0.2V
obviosuly i would that labview could overlap my waveforms and check if the real one stay into the other two.
Solved! Go to Solution.
12-10-2012 07:47 AM
12-10-2012 08:49 AM
i found mask and limit testing VI in labview...but using it can i build a mask that continue in time? or can only define a mask for a small period of time?
and in which way can i let my waveform start in the same moment as my mask?
12-10-2012 09:38 AM
The limits are bound by whatever length of time, however as a practical matter, you would set the limits according to whatever your single acquisition is. You can of course apply each, repeated waveform acquisition to the limit.
The limits and the waveform is aligned with setting the t0 of each to be the same.
