View cluster control as icon
@AmitKaria2k wrote:
humm.. Surprisingly after replacing the frame of the cluster with the same graphic that's used for control references I could not reproduce the same effect.
Once you paste the image to replace the frame make sure you set the Z-order so that it's all the way in front. Otherwise you'll get part of the underlying control show up.
It's customization chicanery that was done.
Message 11 of 14
(1,052 Views)
Yes, when I import the graphics in the cluster frame it gets underlined. Can you explain me the procedure to get it up-front? (Setting Z-order that you mentioned)
Message 12 of 14
(1,049 Views)
I was able to set the z-order to "Move to front". However, after doing this I'm unable to view contents of cluster even while re-ordering cluster contents
Message 13 of 14
(1,044 Views)
It's in the toolbar.
Message 14 of 14
(1,043 Views)
