Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Viewing processor utilization within the application?
marcw
Member
03-25-2004
12:17 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I need to view the processor utiliation from within my application. Is there a call I can make to the operating system or does LabVIEW have the capability to do it? Thanks in advance.
0
Kudos
Message
1
of 3
(2,992 Views)
Reply
Re: Viewing processor utilization within the application?
Mads
Active Participant
03-25-2004
01:33 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If you have LV7 and have installed the .Net framework there is an example included with LV called SimpleTaskMonitor.vi, it does just that - using .Net
Mads Toppe
Check out our Modbus Test Master - developed in LabVIEW
0
Kudos
Message
2
of 3
(2,992 Views)
Reply
marcw
Member
Author
03-25-2004
02:12 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for the quick reply. I'll install the .net framework.
0
Kudos
Message
3
of 3
(2,992 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
