Virtex 7 fpga vc707 with Labview 2014
Is it possible to used virtex 7 fpga vc707 board with Labview 2014?
Thank in advance
(3,536 Views)
Supported
(3,325 Views)
I do not think it is supported.  The GUI is written in LabVIEW (https://www.xilinx.com/support/documentation/boards_and_kits/vc707/ug848-VC707-getting-started-guide...) but that doesn't mean it can be reconfigured (i.e. new bitfile) from LabVIEW FPGA.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,318 Views)
I think that bitfile can be created only in vivado for example. But if we want control vc707, need create *.dll maybe.
(3,313 Views)
Did you mean that I need to write hdl code in vivado/ise and then uploaded that file in labview?
(3,288 Views)
Maybe. For example, HSDIO use dll to connect with Labview. Also may use COM port to connect to VC707.
(3,285 Views)
